coq-club - Re: reductions
Re: reductions
chronological Thread
  • From: Patrick Loiseleur <Patrick.Loiseleur AT lri.fr>
  • To: Marc Bezem <Marc.Bezem AT phil.ruu.nl>
  • Cc: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr.Dimitri.Hendriks@phil.ruu.nl (Dimitri Hendriks)
  • Subject: Re: reductions
  • Date: Wed, 8 Apr 1998 17:04:49 +0200
In his message of Wed April 8, 1998, Marc Bezem writes:
> Hallo,
> How come that sometimes Simpl takes over a minute, whereas Compute
> is almost instantaneous?
It's fairly simple : Compute does dummy bdi-normalization and is optimized
to do that quickly. Simpl does more complicate things : when it
encouters a Fixpoint applied to a constuctor, it unfolds the Fixpoint,
does a step of iota-reduction and then searches occurences of the
unfolded fixpoint and re-fold these occurences (i.e. replace the
corpus of the fixpoint by the name of the constant). For example :
Coq < Eval Simpl in [n,m:nat](plus (S (S m)) n).
     = [n,m:nat](S (S (plus m n)))
     : nat->nat->nat
Coq < Eval Compute in [n,m:nat](plus (S (S m)) n).
     = [n,m:nat]
        (S
          (S
            (Fix plus{plus [n0:nat] : nat->nat :=
                        [m0:nat]
                         Cases n0 of
                           O => m0
                         | (S p) => (S (plus p m0))
                         end} m n)))
     : nat->nat->nat
So :
1) It's normal than Simpl does only partial reduction
2) It's also normal that Simpl is quite (very) slow : this sort of
reduction will be too hard to optimize.
Best regards,
Papageno
