- From: Patrick Loiseleur <Patrick.Loiseleur AT lri.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Emacs tricks for Coq developpers
- Date: Wed, 6 May 1998 16:38:50 +0200
Dear Coq users,
Here are a few lines that you can insert in your .emacs. In defines
the functions :
coq-find-file
coq-find-file-read-only
That search a file in the $COQTOP subtrees, and completes the suffixe
.ml, .mli, .ml4 or .v if not given. For example
M-x coq-find-file and then term
opens $COQTOP/src/constr/term.ml. That tool can be useful when
developing tactics in Coq.
The following functions are also defined :
gml
gmli
gml4
gv
They do a grep in all the .ml files (resp. .mli, .ml4 or .v) of the
$COQTOP subdirectories for the given regular expressions.
Best regards
(defvar coq-load-path (let ((coqtop (getenv "COQTOP")))
(cons (concat coqtop "/")
(cons (concat coqtop "/doc/")
(cons (concat coqtop "/doc/library/")
(cons (concat coqtop "/doc/omega/")
(cons (concat coqtop "/src/")
(cons (concat coqtop "/src/config/")
(cons (concat coqtop "/src/constr/")
(cons (concat coqtop "/src/env/")
(cons (concat coqtop "/src/launch/")
(cons (concat coqtop "/src/lib/")
(cons (concat coqtop "/src/lib/stream-pp/")
(cons (concat coqtop "/src/lib/util/")
(cons (concat coqtop "/src/link/")
(cons (concat coqtop "/src/man/")
(cons (concat coqtop "/src/meta/")
(cons (concat coqtop "/src/parsing/")
(cons (concat coqtop "/src/proofs/")
(cons (concat coqtop "/src/syntax/")
(cons (concat coqtop "/src/tactics/")
(cons (concat coqtop "/src/typing/")
(cons (concat coqtop "/states/")
(cons (concat coqtop "/tactics/")
(cons (concat coqtop "/tactics/contrib/")
(cons (concat coqtop "/tactics/contrib/polynom/")
(cons (concat coqtop "/tactics/contrib/extraction/")
(cons (concat coqtop "/tactics/contrib/linear/")
(cons (concat coqtop "/tactics/contrib/natural/")
(cons (concat coqtop "/tactics/contrib/omega/")
(cons (concat coqtop "/tactics/contrib/reflexion/")
(cons (concat coqtop "/tactics/tcc/")
(cons (concat coqtop "/tactics/programs/")
(cons (concat coqtop "/tactics/programs/gop/")
(cons (concat coqtop "/theories/")
(cons (concat coqtop "/theories/ARITH/")
(cons (concat coqtop "/theories/BOOL/")
(cons (concat coqtop "/theories/DEMOS/")
(cons (concat coqtop "/theories/DEMOS/OMEGA/")
(cons (concat coqtop "/theories/DEMOS/OMEGA/ARITH-OMEGA/")
(cons (concat coqtop "/theories/DEMOS/PROGRAMS/")
(cons (concat coqtop "/theories/INIT/")
(cons (concat coqtop "/theories/LISTS/")
(cons (concat coqtop "/theories/LOGIC/")
(cons (concat coqtop "/theories/RELATIONS/")
(cons (concat coqtop "/theories/RELATIONS/WELLFOUNDED/")
(cons (concat coqtop "/theories/SETS/")
(cons (concat coqtop "/theories/SORTING/")
(cons (concat coqtop "/theories/TESTS/")
(cons (concat coqtop "/theories/ZARITH/")
(cons (concat coqtop "/theories/ZARITH/WITH-OMEGA/")
(cons (concat coqtop "/tools/")
(cons (concat coqtop "/tools/camlp4/")
(cons (concat coqtop "/tools/coq-tex/")
(cons (concat coqtop "/tools/coqdep/")
(cons (concat coqtop "/tools/do_Makefile/")
(cons (concat coqtop "/tools/emacs/")
(cons (concat coqtop "/tools/filters/")
(cons (concat coqtop "/tools/gallina/")
(cons (concat coqtop "/tools/coqinstall/") nil
(defun coq-find-file (filename)
"Find and open a file in the $COQTOP subdirectories"
(interactive "sFind a coq file: ")
(catch 'answer
(mapcar
'(lambda (dir)
(mapcar
'(lambda (suf)
(let ((try (concat dir (concat filename suf))))
(and (file-readable-p try)
(null (file-directory-p try))
(progn
(find-file try)
(throw 'answer try)))))
'(".ml" ".ml4" ".mli" ".v" "")))
coq-load-path)
(message "No file %s in coqtop subdirectories" filename)
nil))
(defun coq-find-file-read-only (filename)
"Find and open READ-ONLY a file in the $COQTOP subdirectories"
(interactive "sFind a coq file read-only: ")
(catch 'answer
(mapcar
'(lambda (dir)
(mapcar
'(lambda (suf)
(progn
(find-file-read-only try)
coq-load-path)
nil))
(defun grepcoq (file-pattern pattern)
"Does grep pattern in all files whose name matches file-pattern in
(shell-command (concat (concat "find "
(getenv "COQTOP")
" -name "
file-pattern
" -exec grep -n \""
pattern
"\" {} \\; -print"))))
(defun gml (pattern)
"Does a grep in all ml files of the $COQTOP subdirectories"
(interactive "sGrep in Coq ml files the regexp: ")
(grepcoq "\\*.ml" pattern))
(defun gmli (pattern)
"Does a grep in all mli files of the $COQTOP subdirectories"
(interactive "sGrep in Coq mli files the regexp: ")
(grepcoq "\\*.mli" pattern))
(defun gml4 (pattern)
"Does a grep in all ml4 files of the $COQTOP subdirectories"
(interactive "sGrep in Coq ml4 files the regexp: ")
(grepcoq "\\*.ml4" pattern))
(defun gv (pattern)
(interactive "sGrep in Coq vernac files the regexp: ")
(grepcoq "\\*.v" pattern))
- Emacs tricks for Coq developpers, Patrick Loiseleur
