- From: Pablo.Argon AT lan10.ec-nantes.fr (Pablo ARGON)
- To: coq-club AT pauillac.inria.fr
- Cc: argon AT lan10.ec-nantes.fr
- Subject: Fixpoint definition
- Date: Wed, 6 May 1998 16:33:05 +0100 (WET DST)
Hello all,
I have a rather "classical" problem defining a Fixpoint:
a not well-formed error.
Because of the syntactical constraint of fixpoint definition, I can
define a recursive function which decreases sometimes one argument,
sometimes other one at each call, i.e. I know that it eventually ends.
A well-known example of such an algorithm is list merge (of two sorted
list).
My question is: there some "general transformation" to make this
class of algorithms acceptable by Coq ?
At the end of this mail you will find my problematic AuxDeCode function with
some extra definitions.
NB: I tried to transform my function using a recipe given by
Christine Paulin for the ackerman function
(cf. coq-list, Subject: Re: Fixpoint vs Recursive Definition)
but I didn't success...
Thanks in advance!
Pablo Argon
Miscelaneous question:
---quotation-----------------------------------------------------------------
>From
>Benjamin.Werner AT inria.fr
> Tue May 5 22:02:33 1998
Date: Tue, 5 May 1998 18:56:37 +0200 (MET DST)
The Reference Manual for Coq V6.2 has been updated and reorganised,
the chapters concerning syntactic extensions and customized
tactics have been completely rewritten. The documentation is also=20
available in html format. Both versions of the documentation are still
in draft format. =20
Where can I find the html format documentation ?
>>>COQ code (6.2)<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Require PolyList.
Inductive Alphabet :Set := a : Alphabet | b : Alphabet.
Record Descriptor : Set := mkD { l : (list nat) ; na : nat;
nb : nat ; m : (list Alphabet)}.
Fixpoint Equal_nat [m:nat; n:nat]: bool :=
Cases m of
O=> Cases n of
O => true
| _ => false
end
| (S pm)=> Cases n of
O => false
|(S pn)=>(Equal_nat pm pn)
end
end.
Fixpoint AuxDeCode [l:(list nat);na,nb:nat] : (list Alphabet)-> Descriptor :=
[m:(list Alphabet)]
Cases l of
nil => (mkD l na nb (rev m))
|(cons x rl) => Cases (Equal_nat x nb) of
true => (AuxDeCode rl (pred na) nb (cons a
m))
|false => Cases nb of
O=> (mkD l na nb (rev m))
|(S pnb)=> (AuxDeCode l na pnb
(cons b m))
end
end
end.
>>>end COQ code<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
- Fixpoint definition, Pablo ARGON
- Re: Fixpoint definition, Bruno Barras
