- To: Pablo.Argon AT lan10.ec-nantes.fr (Pablo ARGON)
- Cc: coq-club AT pauillac.inria.fr, argon AT lan10.ec-nantes.fr
- Subject: Re: Fixpoint definition
- Date: Wed, 6 May 1998 17:59:56 +0200 (MET DST)
Hi Pablo,
> Because of the syntactical constraint of fixpoint definition, I can
> define a recursive function which decreases sometimes one argument,
> sometimes other one at each call, i.e. I know that it eventually ends.
> A well-known example of such an algorithm is list merge (of two sorted
> list).
> My question is: there some "general transformation" to make this
> class of algorithms acceptable by Coq ?
The order you need is a lexicographic order on (l,nb). Your definition
requires two embedded fixpoints, one on l, the other one on nb (note
the new syntax of Fix):
Fixpoint AuxDeCode [l:(list nat)] : nat->nat->(list Alphabet)-> Descriptor :=
Fix ADC{ADC [na,nb:nat]: (list Alphabet)->Descriptor :=
[m]
Cases l of
nil => (mkD l na nb (rev m))
| (cons x rl) =>
if (Equal_nat x nb) then (AuxDeCode rl (pred na) nb (cons a m))
else Cases nb of
O => (mkD l na nb (rev m))
| (S pnb) => (ADC na pnb (cons b m))
end
end}.
You can also put the fixpoint deeper, to allow Case reductions on l,
when nb is not in constructor form, but you have to take care that m
changes along the recursives calls (while na changes only when l
does). You have to abstract and apply both nb and m:
[na;nb;m]
Cases l of
| (cons x rl) =>
(Fix ADC{ADC [nb:nat]: (list Alphabet)->Descriptor :=
[m]if (Equal_nat x nb) then (AuxDeCode rl (pred na) nb (cons a m))
else Cases nb of
| (S pnb) => (ADC pnb (cons b m))
end} nb m)
end.
In both case, you can prove the fixpoint equation you wanted initially:
Goal (l:(list nat))(na,nb:nat)(m:(list Alphabet))
(AuxDeCode l na nb m)
=(Cases l of
| (cons x rl) =>
else
Cases nb of
| (S pnb) => (AuxDeCode l na pnb (cons b m))
end
end).
Destruct l; Destruct nb; Reflexivity.
Save.
Since nb is used in (Equal_nat x nb), you cannot put the second Fix
deeper. This one is wrong, and you cannot prove the equation:
[na;nb;m]
Cases l of
| (cons x rl) =>
else (Fix ADC{ADC [nb:nat]: (list Alphabet)->Descriptor :=
[m]Cases nb of
end} nb m)
end.
Bruno Barras.
Projet Coq - INRIA Rocquencourt
tel : +33 1 39 63 53 16
mailto:Bruno.Barras AT inria.fr
http://pauillac.inria.fr/~barras
- Fixpoint definition, Pablo ARGON
- Re: Fixpoint definition, Bruno Barras
