- To: Bruno.Barras AT cl.cam.ac.uk
- Cc: coq-club AT pauillac.inria.fr, Bruno.Barras AT cl.cam.ac.uk
- Subject: Re: Parameters in "Definitions"?
- Date: Mon, 15 Feb 1999 18:27:29 GMT
Hi Bruno,
rap> The notation I want almost exists, by using a Fixpoint with a dummy
rap> boolean argument.
barras> I don't understand why you need this extra argument...
I was misled by the manual (p.35) which says the type of the recursive
variable should be inductively defined. I was using a dummy boolean
just to have some inductive argument.
Still, it would be better to make "Definition" accept parameters.
Thanks,
Randy
- Parameters in "Definitions"?, Randy Pollack
- Re: Parameters in "Definitions"?,
Bruno Barras
- Re: Parameters in "Definitions"?, Randy Pollack
- Re: Parameters in "Definitions"?, Patrick Loiseleur
Bruno Barras
