- From: Patrick Loiseleur <Patrick.Loiseleur AT lri.fr>
- To: "Randy Pollack" <rap AT dcs.ed.ac.uk>
- Cc: Bruno.Barras AT cl.cam.ac.uk, coq-club AT pauillac.inria.fr
- Subject: Re: Parameters in "Definitions"?
- Date: Tue, 16 Feb 1999 09:57:50 +0100 (MET)
Dans son message du Monday 15 February, Randy Pollack a écrit :
> Hi Bruno,
> rap> The notation I want almost exists, by using a Fixpoint with a dummy
> rap> boolean argument.
> barras> I don't understand why you need this extra argument...
> I was misled by the manual (p.35) which says the type of the recursive
> variable should be inductively defined. I was using a dummy boolean
> just to have some inductive argument.
> Still, it would be better to make "Definition" accept parameters.
> Thanks,
> Randy
It is a good idea to accept the syntax :
Definition f [n:nat; m,x:bool] := ...
because it is symmetric with the "Fixpoint" command.
I remember this point was discussed in the Coq team, but it wasn't
implemented.
It will be added in the next release. People that cannot wait should
send me a note and they will receive a patch against the 6.2.4
Best regards,
PL
- Parameters in "Definitions"?, Randy Pollack
- Re: Parameters in "Definitions"?,
Bruno Barras
Randy Pollack
- Re: Parameters in "Definitions"?, Patrick Loiseleur
Randy Pollack
Bruno Barras
