coq-club - Re: Parsing "Fixpoint".
chronological Thread
  • From: Patrick Loiseleur <Patrick.Loiseleur AT lri.fr>
  • To: "Randy Pollack" <rap AT dcs.ed.ac.uk>
  • Cc: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr, Bruno.Barras AT cl.cam.ac.uk
  • Subject: Re: Parsing "Fixpoint".
  • Date: Tue, 16 Feb 1999 10:07:56 +0100 (MET)
Dans son message du Monday 15 February, Randy Pollack a écrit :
>   Coq < Fixpoint test [a:Prop][b:Set] : Set := b.
>   Toplevel input, characters 23-24
>   > Fixpoint test  [a:Prop][b:Set] : Set := b.
>   Syntax error: ':' expected after ']' (in [Vernac.onerec])
>   Coq < Fixpoint test [a:Prop;b:Set] : Set := b.
>   Warning: test is non-recursively defined
> You probably don't consider this a bug, but if "[a:Prop][b:Set]" and
> "[a:Prop;b:Set]" mean the same thing, why can't they both be parsed?
> Randy
It is not the same thing, indeed. "[a:Prop][b:Set]t" and
"[a:Prop;b:Set]t", where t is a term, are two different notations for
the same term.
But in the commands "Fixpoint test [a:foo;b:bar] := t" and
"Fixpoint test [a:foo] := [b:bar]t" are different. In the first one,
the recursive arguement is "b" and it is "a" in the second one.
If we accept the syntax "Fixpoint test  [a:Prop][b:Set]" as a
shorthand for "Fixpoint test [a:Prop; b:Set]" the difference between
"Fixpoint test  [a:Prop][b:Set] := t" and "Fixpoint test [a:foo] := [b:bar]t"
will be hard to explain.
Another point I didn't mention in my previous mail : thank you for
your comments and remarks. Feedback is always welcome.
Patrick Loiseleur
