- To: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr, Bruno.Barras AT cl.cam.ac.uk
- Subject: Parsing "Fixpoint".
- Date: Mon, 15 Feb 1999 19:23:37 GMT
Coq < Fixpoint test [a:Prop][b:Set] : Set := b.
Toplevel input, characters 23-24
Syntax error: ':' expected after ']' (in [Vernac.onerec])
Coq < Fixpoint test [a:Prop;b:Set] : Set := b.
Warning: test is non-recursively defined
You probably don't consider this a bug, but if "[a:Prop][b:Set]" and
"[a:Prop;b:Set]" mean the same thing, why can't they both be parsed?
Randy
- Parsing "Fixpoint"., Randy Pollack
- Re: Parsing "Fixpoint"., Patrick Loiseleur
