coq-club - Re: Unfolding definitions?
chronological Thread
  • To: Patrick.Loiseleur AT lri.fr
  • Cc: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr
  • Subject: Re: Unfolding definitions?
  • Date: Wed, 3 Mar 1999 17:27:13 GMT
Patrick,
loisel> I'm not sure I've exactly understood what you mean.
Let me ask my question with a clear example.  Consider the commands:
  Reset Initial.
  Require Export Relations.
  Record Setoid : Type :=
    { s_el    :> Set;
      s_eq    :  (relation s_el);
      s_refl  :  (reflexive s_el s_eq)
I try to make s_refl into a hint for s_eq:
  Hints Resolve s_refl.
At this point s_refl is NOT known as a hint for s_eq:
  Coq < Print Hint s_eq.
  For s_eq ->   In the database v62 :
    In the database sets :
    In the database core :
Now I try to make the unfolded form into a hint:
  Definition s_refl_unfolded : (S:Setoid)(x:S)(s_eq S x x) := s_refl.
  Hints Resolve s_refl_unfolded.
The unfolded form DOES become a hint for s_eq.
  Apply s_refl_unfolded(0)
The question: how can I use s_refl as a hint for s_eq without defining
an unfolded form?
Randy
