- To: Patrick.Loiseleur AT lri.fr
- Cc: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr
- Subject: Re: Unfolding definitions?
- Date: Thu, 4 Mar 1999 18:29:33 GMT
I don't accept Patrick's answer "What gets you confused is probably
... the difference between opaque and transparent constants."
Consider the following examples, where "reflexive" is transparent in
both examples:
Reset Initial.
Variables A:Set; R:A->A->Prop.
Definition reflexive : Prop := (a:A)(R a a).
Lemma test: (refl:reflexive)(a:A)(R a a).
Intros.
Apply refl.
We get "Subtree proved!". On the other hand:
Reset Initial.
Record Setoid : Type := { refl: reflexive }.
Lemma test: (S:Setoid)(a:A)(R a a).
Intros.
Apply refl. (* fails *)
This fails with
test < Apply refl.
Error during interpretation of command:
Apply refl.
Error: Impossible to unify reflexive with (R a a)
However if we define an type-expanded version of "refl"
Definition refl_unfolded: Setoid->(a:A)(R a a) := refl.
Apply refl_unfolded.
This works. In this case, instead of defining "refl_unfolded" we
could also use "Apply (refl S)." (Why??)
But we can't make "(refl S)" a Hint, because "S" is local to the lemma
and is not known at top-level.
So my question still stands how to avoid this ugly expanded-version
trick?
Randy
- Unfolding definitions?, Randy Pollack
- Re: Unfolding definitions?,
Patrick Loiseleur
- Re: Unfolding definitions?, Randy Pollack
Christine Paulin
Patrick Loiseleur
