- To: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr
- Subject: Inversion and computation
- Date: Mon, 5 Apr 1999 14:26:47 +0100
I have defined the head of a non-empty listn as follows.
Implicit Arguments On.
Section Listn.
Variable A : Set.
Inductive listn : nat->Set :=
niln: (listn O)
| consn: (a:A)(n:nat)(listn n)->(listn (S n)).
Definition hdn: (n:nat)(l:(listn (S n)))A.
Intros n l. Inversion l. Exact a.
Defined.
I was extremely impressed by the Inversion tactic that can handle this
definition (in LEGO we have to work much harder; see the development
of "vectors" in the LEGO library), but when I tried to use the
definition of "hdn" I found it doesn't compute as I expected
Coq < Eval Compute in (hdn (consn O (niln nat))).
= (<[n:nat]nat->(listn nat n)->nat>
Cases
(sym_eq nat O O
(f_equal nat nat
[e:nat]Cases e of
O => O
| (S a) => a
end (S O) (S O) (refl_equal nat (S O))))
of
refl_equal => [a:nat; _:(listn nat O)]a
end O (niln nat))
: nat
I assume the cause is the Inversion tactic, but I don't understand
what's going on. I'd appreciate both an explanation of what's
happening, and suggestions how to make such definitions as "hdn".
Randy
- Inversion and computation, Randy Pollack
- Re: Inversion and computation, Cristina Cornes
