- To: rap AT dcs.ed.ac.uk (Randy Pollack)
- Cc: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr
- Subject: Re: Inversion and computation
- Date: Mon, 5 Apr 1999 04:49:30 +0300 (GMT+3:00)
Hello Randy,
> ....but when I tried to use the
> definition of "hdn" I found it doesn't compute as I expected
> Coq < Eval Compute in (hdn (consn O (niln nat))).
> = (<[n:nat]nat->(listn nat n)->nat>
> Cases
> (sym_eq nat O O
> (f_equal nat nat
> [e:nat]Cases e of
> O => O
> | (S a) => a
> end (S O) (S O) (refl_equal nat (S O))))
> of
> refl_equal => [a:nat; _:(listn nat O)]a
> end O (niln nat))
> : nat
The inversion tactic uses some lemmas like sym_eq and f_equal that
are not automatically expanded during Compute. If you make these
lemmas transparent, then delta expansion is performed and you
obtain the expected computation.
Transparent sym_eq.
Transparent f_equal.
= O
: nat
I hope this helps.
Best regards,
cristina
- Inversion and computation, Randy Pollack
- Re: Inversion and computation, Cristina Cornes
