- From: Pablo Argon <Pablo.Argon AT ircyn.ec-nantes.fr>
- To: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Refine problems
- Date: Thu, 15 Apr 1999 10:18:15 +0100
- Organization: IRCyN
Hello,
I'm trying to re-play (using Coq 6.2.4 on linux) Eduardo Gimenez's
proof
of well-founded recursion given in the tutorial on recursive types
(http://pauillac.inria.fr/coq/ps/RecTutorial.v.ps) page 34,
with the div function.
The proof of div (p.36) doesn't save:
Theorem div: (x:nat)(y:nat)(Acc nat Lth x)->nat.
Proof.
Fix 3;Intros x y H.
Refine
If (iseq x O) then O
else If (iseq y O) then x
else (S (div (minus x y) y ?)).
Apply (decrease x y); Assumption.
Guarded.
(*Coq says*)
Condition violated : Recursive call applied to an illegal term
The recursive definition
[x,y:nat; H:(Acc nat Lth x)]
Cases (iseq x O) of
(left _) => O
| (right a) =>
Cases (iseq y O) of
(left _) => x
| (right a0) => (S (div (minus x y) y (decrease x y H a a0)))
end
end
is not well-formed
May someone explain me why?
Thank you all by advance,
Pablo Argon
NB: follows the whole script I used.
PABLO ARGON
IRCyN (UMR 6597)
École Centrale Nantes,
1 rue la Noë, BP 92101
44321 Nantes cedex 3,
FRANCE
Tél: 02 40 37 69 23
Fax: 02 40 37 69 30
(* Exemple du INRIA-Report 0221 (E.Gimenez) p33-ss *)
Require Minus.
Require Refine.
Require EqDecide.
Section Principle_of_double_induction.
Variable P: nat -> nat -> Prop.
Hypothesis base_case1 : (x:nat)(P O x).
Hypothesis base_case2 : (x:nat)(P x O).
Hypothesis inductive_hyp : (n,m:nat)(P n m)->(P (S n) (S m)).
Fixpoint nat_double_ind [n:nat] : (m:nat)(P n m) :=
[m:nat]<P>Cases n m of
O x => (base_case1 x)
| x O => (base_case2 x)
| (S x) (S y)=>(inductive_hyp x y (nat_double_ind x y))
end.
End Principle_of_double_induction.
Inductive Lth [n:nat] : nat->Prop :=
Lth_intro1: (Lth n (S n))
| Lth_intro2: (m:nat)(Lth n m)->(Lth n (S m)).
Lemma minus_O : (n:nat)(minus n O)=n.
Proof.
Destruct n;Auto.
Qed.
Lemma smaller: (x,y:nat)(Lth (minus x y) (S x)).
Proof.
(Intros x y; Pattern y x; Elim x using nat_double_ind; Intro n).
Cut (n:nat)(minus n O)=n.
Intro H.
Rewrite H.
Constructor 1.
Auto with v62.
Simpl.
Constructor.
Intros.
Simpl.
(Constructor 2; Assumption).
Qed.
Lemma smallerSS: (x,y:nat)~x=O->~y=O->(Lth (minus x y) x).
Proof.
(Destruct x; Destruct y;
((Simpl; Intros; Apply smaller; Assumption)) Orelse
((Intros; Absurd O=O; Auto with v62))).
Qed.
Theorem decrease:
(x,y:nat)(Acc nat Lth x)->
~x=O->~y=O->(Acc nat Lth (minus x y)).
Proof.
Intros x m H.
Case H.
Intros n h xno yno.
Apply h.
(Apply smallerSS; Assumption).
Qed.
Theorem iseq: (x:nat)(y:nat){x=y}+{~x=y}.
Proof.
Decide Equality.
Qed.
Grammar command command1 :=
ruleIf ["If" command($c1)
"then" command($c2)
"else" command($c3)] ->
[<<Cases $c1 of
(left _) => $c2
|(right _) => $c3
end>>].
(* ------------ fonction div ------------*)
Proof.
Fix 3;Intros x y H.
Refine
Guarded.
- Refine problems, Pablo Argon
- <Possible follow-ups>
- Re:Refine problems, Eduardo Gimenez
