- From: Benjamin Werner <Benjamin.Werner AT inria.fr>
- To: sacerdot AT students.cs.unibo.it (Claudio Sacerdoti Coen)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: Could I prove ~nat==bool?
- Date: Mon, 27 Sep 1999 17:37:48 +0200 (MET DST)
Ciao Claudio,
> could I prove that two "different" inductive types are not equal in Type?
You can, provided they are really different ! (see below)
> example: ~nat==bool is provable? If yes, how? If no, why really?
To prove it, you have to exhibit a property verified by bool and
(provably) not by nat.
One such property is "having at most two elements", formaly:
Definition P := [X:Set](EX x:X | (EX y:X | (z:X)z=x\/z=y)).
This predicate is easily provable for bool, and proven false for nat.
I should have let you do the proof, since it is a good and fun
exercise. But I could not resist ! :)
A possible solution is below. There sure are shorter ones.
Note however that if you had redefined an inductive type isomorphic to
the booleans but with a new name:
Inductive calcio_bo : Set :=
rosso : calcio_bo | azzuro : calcio_bo.
Then you could not prove ~bool==calcio_bo. Actually in former versions of
Coq, these two definitions were convertible (and thus equal).
Cheers,
Benjamin
>>>>>>>>>>> Spoiler
Lemma Pb : (P bool).
Exists true; Exists false; Intros b; Elim b; Auto.
Qed.
Lemma Pnat : ~(P nat).
Unfold not; Destruct 1; Intros x; Destruct 1; Intros y hy.
Elim (hy O); Intros; Elim (hy (S O)); Intros; Elim (hy (S (S O)));
Intros.
Cut O=(S O); Try Discriminate; EAuto .
Apply trans_equal with x; Auto.
Cut O=(S O); Try Discriminate; Apply trans_equal with x; Auto.
Cut O=(S (S O)); Try Discriminate; Apply trans_equal with x; Auto.
Cut (S O)=(S (S O)); Try Discriminate; Apply trans_equal with y; Auto.
Cut (S O)=(S (S O)); Try Discriminate; Apply trans_equal with x; Auto.
Cut O=(S (S O)); Try Discriminate; Apply trans_equal with y; Auto.
Cut O=(S O); Try Discriminate; Apply trans_equal with y; Auto.
Qed.
Goal ~nat==bool.
Unfold not; Intros; Apply Pnat.
Rewrite H.
Exact Pb.
> T.I.A.
> C.S.C.
> Real Name: Claudio Sacerdoti Coen
> Address: via del Colle n.6
> S. Lazzaro di Savena (BO)
> Italy
> e-mail:
> sacerdot AT cs.unibo.it
- Could I prove ~nat==bool?, Claudio Sacerdoti Coen
- Re: Could I prove ~nat==bool?, Benjamin Werner
