- To: coq-club AT pauillac.inria.fr
- Cc: ctm AT dcs.ed.ac.uk
- Subject: Re: Can I define an equality dependent on another one?
- Date: Tue, 28 Sep 1999 15:46:28 -0400
This is somewhat tangential to the discussion of one equality
depending on another, but Conor McBride at Edinburgh has defined a new
equality, the so-called "John Major equality", which allows the types
to be different in the type but not in the introduction rule:
Inductive jmeq : (A:Type)(B:Type) A -> B -> Prop :=
jmrefl : (A:Type)(a:A)(jmeq A A a a).
This equality is nice in how it interacts with substitution, since if
you have A : Type, P : A -> Prop and H : (jmeq A A a b), then you
don't need to use a coercion to form (jmeq (P a) (P b) p q) for proofs
p : (P a) and q : (P b). This is useful when you do inductive proofs
where a and b really are the same thing.
Healf Goguen
- Can I define an equality dependent on another one?, Claudio Sacerdoti Coen
- Re: Can I define an equality dependent on another one?,
Frederic Blanqui
- Re: Can I define an equality dependent on another one?, Healfdene Goguen
- Re: Can I define an equality dependent on another one?, Conor McBride
Frederic Blanqui
