coq-club - problem extracting dependent records
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: problem extracting dependent records
  • Date: Tue, 05 Oct 1999 15:57:17 +0200
  • Organization: IRISA, Campus de Beaulieu, 35042 Rennes Cedex, France
Bonjour,
Is the following a bug, or is there some reason to not expect dependent
records to extract? Is there any way to get round this?
Record Mytype : Set := mkType { n : nat ; m : (sig nat (ge n))}.
Write CamlLight File "Mytype" [Mytype].
Error during interpretation of command:
Somebody raised a Failure exception
"not an ML type".
If this is in user-written tactic code, then it needs to be modified.
If this is in system code, then it needs to be reported.
However, extraction works as expected with the likes of
Definition MyStype := (sigS nat ([n:nat](sig nat (ge n)))).
Ewen Denney
