coq-club - Re: problem extracting dependent records
chronological Thread
  • From: Jean-Christophe Filliatre <filliatr AT lri.fr>
  • To: Ewen Denney <denney AT irisa.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: problem extracting dependent records
  • Date: Wed, 6 Oct 1999 09:56:08 +0200 (MET DST)
> Is the following a bug, or is there some reason to not expect dependent
> records to extract? Is there any way to get round this?
> Record Mytype : Set := mkType { n : nat ; m : (sig nat (ge n))}.
The extraction of Mytype is the following :
Coq < Extraction Mytype.
Mytype ==>
    Inductive Mytype : Set :=  mkType : nat->([P:Set]P nat)->Mytype
and, as you can notice, there is a redex, which is not an ML type
(there is no type operator in ML). If it was reduced, then the type
would be an ML type.
So, this is a bug, since types should be reduced before being
extracted, at least just before the ML extraction.
I send you a patch if I can find an easy solution to that problem.
Jean-Christophe FILLIATRE
mailto:Jean-Christophe.Filliatre AT lri.fr
  http://www.lri.fr/~filliatr
