- To: coq-club AT pauillac.inria.fr
- Subject: Re: Feature request
- Date: Fri, 19 Nov 1999 10:58:26 +0100 (MET)
Dear Hugo,
>More generally, do you mind a syntactic definition that
>hides the required proof of y#0 in the de def of "/" and add
>the proof obligation as a goal, possibly proving it
>automatically.
I wouldn't _mind_ that of course :-), but what I was thinking
of was something like having the possibility to write:
(divide x y (LATEST y#0))
where "(LATEST T)" means the latest object of type T that has
been introduced (better syntax would be nice of course). I
was talking about _expressions,_ not about tactics.
I mean, I want to be able to use these kind of expressions in
a Check etc., and in that case there certainly is not the
possibility to add proof obligations. I even might not be
inside a goal when I do the Check: so there is not anything
like "proving" possible then.
Freek
- Feature request, Freek Wiedijk
- Re: Feature request,
Hugo Herbelin
- Re: Feature request, Freek Wiedijk
Jean-Christophe Filliatre
Freek Wiedijk
Benjamin Werner
- Re: Feature request, Pierre Courtieu
Benjamin Werner
Freek Wiedijk
Hugo Herbelin
