- To: coq-club AT pauillac.inria.fr
- Subject: Re: Feature request
- Date: Fri, 19 Nov 1999 15:34:30 +0100 (MET)
Dear Benjamin,
>In John Harrison's terminology, this would mean introducing
>a little piece of declarative proof-style, in coq's
>overhelmingly procedural style
Exactly! Thank you for pointing this out. My way to look at
proof checking happens to be very declarative, I don't know
why (the "Step" tactic we use here for equational reasoning
also is the declarative way to do that.) Unfortunately for
me, almost all major systems that I know of seem to be
procedural :-)
>Then, the next step is probably to have the search in the
>environment being done modulo some isomorphisms over the
>type/proposition, in the style of the searchiso facility.
I don't think I need anything like this for the application
that I had in mind.
>All this obviously raises questions of efficiency
That was my original question. I don't think I need
convertibility, if that helps. But looking at the parameters
and definitions would be real nice. However, if that's too
hard, with a sufficient number of "lets" (or "Cuts", in a
procedural situation :-)) I can pull them into the local
context of my expression, so even that is not _really_
necessary.
>So I would advocate to be careful and propose a feature
>as modest as possible, if it appears necessary.
Ah. I think hardly _anything_ in life is really necessary :-)
But having this feature might make the stuff I do quite a bit
more readable. (And maybe it would make it much slower too.)
Freek
- Feature request, Freek Wiedijk
- Re: Feature request,
Hugo Herbelin
Freek Wiedijk
Jean-Christophe Filliatre
Freek Wiedijk
Benjamin Werner
- Re: Feature request, Freek Wiedijk
- Re: Feature request, Pierre Courtieu
Benjamin Werner
Freek Wiedijk
Freek Wiedijk
Hugo Herbelin
