coq-club - Failed to extract
Failed to extract
chronological Thread
  • From: Mark-Oliver Stehr <stehr AT informatik.uni-hamburg.de>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Failed to extract
  • Date: Wed, 08 Dec 1999 07:45:28 -0800
I just switched to the new 6.3.1 version of
COQ and it seems that the following warning
ocurrs more often than in previous versions:
Warning: Failed to extract
The warning appears after finishing a proof
with Qed. Nevertheless the proof object
seems to be correctly generated under the name of the
theorem.
So the question is: What does this warning
mean precisely, in particular, can I be sure
that the proof is valid ?
I suspect that the warning has to do something
with program extraction, a feature that I am
currently not using.
Thanks in advance,
Mark-Oliver
Mark-Oliver Stehr
Universit"at Hamburg, Fachbereich Informatik
Arbeitsbereich Theoretische Grundlagen der Informatik
Vogt-K"olln-Str. 30, D-22527 Hamburg
Tel. +49-40-42883-2245  **  (Fax -2246)
e-mail:
http://www.informatik.uni-hamburg.de/TGI/mitarbeiter/wimis/stehr.html
