- To: stehr AT informatik.uni-hamburg.de (Mark-Oliver Stehr)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: Failed to extract
- Date: Wed, 29 Dec 1999 12:27:58 +0100 (MET)
Dear Mark-Oliver,
> I just switched to the new 6.3.1 version of
> COQ and it seems that the following warning
> ocurrs more often than in previous versions:
> Warning: Failed to extract
> So the question is: What does this warning
> mean precisely, in particular, can I be sure
> that the proof is valid ?
> I suspect that the warning has to do something
> with program extraction, a feature that I am
> currently not using.
Yes, the warning means Coq has not been able to extract a
computation meaning of the proof. This occurs typically when handling
objects at the Type level.
It does not invalidate the correctness of the proof. Just that a
program won't be extracted from the proof.
Best wishes,
Hugo
- Failed to extract, Mark-Oliver Stehr
- Re: Failed to extract, Hugo Herbelin
