- To: "'coq AT pauillac.inria.fr'" <coq AT pauillac.inria.fr>
- Subject: Beginner's question about induction proof
- Date: Wed, 5 Jan 2000 09:31:06 -0000
Title: Beginner's question about induction proof
(I'm not sure if this is the right place to ask this question.)
I'm trying to do a simple proof in Coq and I get a message: "Unable to do second order unification". Am I doing this the right way?
Regards,
Michael Abbott
Here's my Coq code:
(* This file defines operations on the free algebra of paths generated by a
* collection of nodes and arrows. *)
Implicit Arguments On.
Section FreeGraph.
(* N is a type of nodes, A(X,Y) a type of arrows (directed paths) from X to Y. *)
Variable N : Type.
Variable A : N -> N -> Type.
(* FreeGraph(X,Y) is the type of paths from X to Y. *)
Inductive FreeGraph : N -> N -> Type :=
nil : (X: N) (FreeGraph X X) |
cons : (X, Y, Z: N) (A X Y) -> (FreeGraph Y Z) -> (FreeGraph X Z).
(* The append function joins together two paths to yield a new path. *)
Definition append : (X, Y, Z: N)
(FreeGraph X Y) -> (FreeGraph Y Z) -> (FreeGraph X Z).
Intros X Y Z f. Elim f. Intros Y' g. Apply g.
Intros X' X'' Y' a f' app g. Apply (cons a (app g)).
Defined.
(* I tried to define append directly like this, but I can't make this type check:
Fixpoint append [X, Y, Z: N; f: (FreeGraph X Y)] :
(FreeGraph Y Z) -> (FreeGraph X Z) :=
Cases f of
(nil X) => [g: (FreeGraph X Z)] g
| (cons X X' Y a f') => [g: (FreeGraph Y Z)] (cons a (append f' g)) end.
Variable W, X, Y: N.
Variable a: (A W W).
Variable f: (FreeGraph W X).
Variable g: (FreeGraph X Y).
Lemma append_const_dist : (append (cons a f) g) == (cons a (append f g)).
Elim f.
(* At this point I get the error message about "second order unification". *)
- Beginner's question about induction proof, Michael Abbott
- <Possible follow-ups>
Michael Abbott
- Re: Beginner's question about induction proof, Christine Paulin
