- To: Dimitri.Hendriks AT phil.uu.nl (Dimitri Hendriks)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: how to destruct l:(listn O)?
- Date: Sun, 26 Mar 2000 13:58:45 +0200 (MET DST)
[copy to coq-club]
Dear Dimitri Hendriks,
> From the following definition
> Variable A : Set.
> Inductive listn : nat->Set :=
> niln : (listn O)
> | consn : (n:nat)A->(listn n)->(listn (S n)).
> one might expect (listn O) to be inhabited by niln only.
> In other words (l:(listn O)) l = niln, but how to prove it?
> Case analysis on l:(listn O) is not permitted
> ("Cannot solve a second-order unification problem").
You can prove this goal using a more general form of equality
(named eq_dep and defined in file Eqdep) allowing comparison between
terms whose types are only provably equal and not convertible. Then
case analysis is possible.
Lemma eq_dep_niln : (n:nat;l:(listn n))(n=O)->(eq_dep ? ? n l O niln).
Induction l.
Trivial.
Intros;Discriminate.
Qed.
Lemma eq_niln : (l:(listn O))l = niln.
Intro;Apply eq_dep_eq with P:=listn.
Apply eq_dep_niln;Trivial.
Qed.
Best regards,
Hugo
- how to destruct l:(listn O)?, Dimitri Hendriks
- Re: how to destruct l:(listn O)?, Hugo Herbelin
- Re: how to destruct l:(listn O)?, Sylvain BOULM'E
