coq-club - Pattern-matching on a redefined constructor name
chronological Thread
  • From: Guillaume Dufay <Guillaume.Dufay AT sophia.inria.fr>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Pattern-matching on a redefined constructor name
  • Date: Thu, 18 May 2000 11:23:21 +0200
  • Organization: INRIA Sophia Antipolis
Hello,
I'm having a weird problem with the strategie Cases.
Hereafter a small example in Coq :
Require Bool.
Definition is_true := true.
Definition foo := [b:bool]
  Cases b of
    is_true => true |
    _ => false
  end.
Print is_true.
Print foo.
And the result is :
> is_true = true
>     : bool
> foo = [_:bool]true
>     : bool->bool
No pattern-matching is done on the redefined constructor true.
Is that a normal behaviour? Is there a way to avoid this?
Thank you in advance. Regards,
Guillaume Dufay
