coq-club - Re: Pattern-matching on a redefined constructor name
chronological Thread
  • From: Eduardo Gimenez <Eduardo.Gimenez AT trusted-logic.fr>
  • To: Guillaume Dufay <Guillaume.Dufay AT sophia.inria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: Pattern-matching on a redefined constructor name
  • Date: Thu, 18 May 2000 11:52:16 +0200
  • Organization: Trusted Logic
Hi,
As the identifier is_true is not a constructor, Coq considers it   as a
variable. The scope of this variable is the corresponding branch of the case
expression, so it hides the constant is_true that you have previously defined
Hence, your definition is actually equivalent to :
 Definition foo := [b:bool]
   Cases b of
      x => true |
     _ => false
    end.
As x matches any term., the definition is the constant function
[b:bool]true.
Actually, Coq should warn the user about the fact that the last
branch (_ => false) is unreachable.
Cheers,
Eduardo.
Le jeu, 18 mai 2000, vous avez écrit :
> Hello,
> I'm having a weird problem with the strategie Cases.
> Hereafter a small example in Coq :
> Require Bool.
> Definition is_true := true.
>   Cases b of
>     is_true => true |
>     _ => false
>   end.
> Print is_true.
> Print foo.
> And the result is :
> > is_true = true
> >     : bool
> > foo = [_:bool]true
> >     : bool->bool
> No pattern-matching is done on the redefined constructor true.
> Is that a normal behaviour? Is there a way to avoid this?
> Thank you in advance. Regards,
> Guillaume Dufay
Eduardo Gimenez                Tel :   (33) 1 30 97 25 13
Trusted Logic SA               Std :   (33) 1 30 97 25 00
5, rue du Bailliage            Fax :   (33) 1 30 97 25 19
78000 Versailles               Web : www.trusted-logic.fr
