coq-club - strong elimination on non-small inductive types
chronological Thread
  • To: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: strong elimination on non-small inductive types
  • Date: Fri, 19 Jan 2001 15:44:50 -0800
  • Organization: INRIA & Cadence Berkeley Laboratories
Hello all,
        I'm confuse by the following error:
(example completely dummy)
$ coqtop
Welcome to Coq V6.3.1 (December 1999)
Coq < Variable ValuationA : Type.
ValuationA is assumed
Coq < Variable SymbolSet : Set.
SymbolSet is assumed
Coq < Inductive Set GroundTAbs :=
      gta_intro: SymbolSet -> ValuationA -> GroundTAbs.
GroundTAbs_ind is defined
GroundTAbs_rec is defined
GroundTAbs is defined
Coq < Check [y :GroundTAbs ]
            (<Prop> Cases y of (gta_intro s2 va)=>true=true end).
Toplevel input, characters 7-91
> ..... [y :GroundTAbs ]
Error: Incorrect elimination of y in the inductive type
  GroundTAbs
 The elimination predicate Prop has type Type
 It should be one of :
  GroundTAbs->Prop, GroundTAbs->Set, Prop, Set
 Elimination of an inductive object of sort : Type
 is not allowed on a predicate in sort : Set
 because
 strong elimination on non-small inductive types leads to paradoxes.
On the other hand, the following is accepted "as expected":
Variable Valuation : Set.
Inductive Set GroundT :=
gt_intro: SymbolSet -> Valuation -> GroundT.
Check [y :GroundT ]
  (<Prop> Cases y of (gt_intro s2 va)=>true=true end).
Why Coq don't allow the Case analysis in the first definition,
which is simply a "let" ?
Thank you in advance.
best wishes, Pablo
NB: Obviously, I can get around writing:
Coq <   ((s2:SymbolSet)(va:ValuationA)
Coq <     (y=(gta_intro s2 va))-> true=true).
[y:GroundTAbs]
 (s2:SymbolSet; va:ValuationA)y=(gta_intro s2 va)->true=true
     : GroundTAbs->PropVariable Valuation : Set.
Check [ y :GroundT ]
