coq-club - Re: mutually-defined Records
chronological Thread
  • From: Christine Paulin <Christine.Paulin AT lri.fr>
  • To: Hiroyuki Miyoshi <hxm AT cc.kyoto-su.ac.jp>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: mutually-defined Records
  • Date: Mon, 22 Jan 2001 18:07:45 +0100 (MET)
Dear Hiroyuki Miyoshi,
It would be interesting to have an exemple of what you want to
modelise with mutual record.
The record are supposed to be non recurive, actually a recursive
record (because it is defined inductively) will in general lead to an
empty type.
A recursive record should be defined as a coinductive type.
As mentioned by Benjamin, you may first define your records
parameterised by the recursive type
        Record R1 [X,Y:..] := {l1:X; l2:Y}
and then use a coinductive def
        CoInductive X : Set := c1 : (R1 X Y)->X
        with Y : Set : ... -> Y
Christine Paulin
In his message of Mon January 22, 2001, Hiroyuki Miyoshi writes:
> Dear all,
> I am using V.6.3.1 to define some higher-dimensional algebras
> and feel inconvenience of lacking for mutually-defined Records
> (definable as a macro of "Inductive ... with").
> Is that syntax planned to be provided?
> Best regards,
> Hiroyuki Miyoshi
  Christine Paulin-Mohring             mailto :
  LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud,   91405 ORSAY Cedex
  LRI   tel : (+33) (0)1 69 15 66 35       fax : (+33) (0)1 69 15 65 86
  INRIA tel : (+33) (0)1 39 63 54 60       fax : (+33) (0)1 39 63 56 84
