- To: Eduardo.Gimenez AT trusted-logic.fr
- Cc: cuihtlauac.alvarado AT rd.francetelecom.fr, coq-club AT inria.fr
- Subject: Re: let: 7 vs 6
- Date: Tue, 3 Jul 2001 17:46:24 +0200 (MET DST)
Hi,
> Le Thursday 17 May 2001 15:23, vous avez ecrit :
> > Hi all,
> > Ok, we suppose it comes from the new native "let in"
> > construct. Unfortunately, 6.x style could be far more readable,
> > sometimes.
> > Require PolyList.
> > Inductive foo : Set := bar : (list foo)->foo.
> > (* 6.3 : ok; 7.0 : error *)
> > Fixpoint interp [x:foo] : nat :=
> > let f = [l](fold_right plus O (map interp l)) in
> > Cases x of
> > | (bar l) => (f l)
> > end
> I *do* agree with you. Moreover, in Ocaml programs one usually does
> intensive use of the let construction just for readability reasons, that
> is,
> just to name intermediate results. Most of Ocaml code looks like that :
> let f x1 =
> let x2 = (f1 x1) in
> let x3 = (f2 x2) in
> even if x1 and x2 are used once in the body of f.
> If my understanding is good, a let-expansion during the verification of the
> guardedness condition would be sufficient to deal with definitions like
> that.
> Is that actually true ?
Yes, it works with let-expansion. Let's then define the fact to be
guarded as the fact to be guarded when let's are expanded. It will be
available in the next version.
Hugo
PS: for a quick fix, just replace the code for "IsLetIn (x,a,b,c)" on
line 666 of file V7/kernel/typeops.ml by
| IsLetIn (x,a,b,c) ->
check_rec_call env n lst (whd_betadeltaiota env sigma t)
- Re: let: 7 vs 6, Hugo Herbelin
