coq-club - Well founded recursion (Re: [Coq-Club] How widely applicable is Coq? (beginner))
chronological Thread
  • From: David Nowak <David.Nowak AT lsv.ens-cachan.fr>
  • To: George Herson <gherson AT snet.net>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Well founded recursion (Re: [Coq-Club] How widely applicable is Coq? (beginner))
  • Date: Fri, 02 Aug 2002 13:54:24 +0200
Hi,
With the solution proposed by Venanzio, even if we assume the axiom
  (n:nat)(le (1) n)->(Df n)
we cannot run the extracted function in O'Caml:
let rec f n = function
  | Df1 -> S O
  | Dfe (n', h') -> S (f (div2 n') h')
  | Dfo (n', h') -> S (f (S (mult (S (S (S O))) n')) h')
Another way is to use well founded recursion.
Require Arith.
Require Even.
Require Div2.
We first define the following relation:
Inductive R : nat->nat->Prop :=
  r1 : (n:nat)(le (1) n)->(odd n)->(R (S (mult (3) n)) n)
| r2 : (n:nat)(le (1) n)->(even n)->(R (div2 n) n).
We assume it is well founded (by the way, can anyone remind me the name of this conjecture ?):
Axiom R_wf : (well_founded nat R).
We define the function by proof:
Definition f [n:nat] : (le (1) n)->nat.
Proof.
Change (n:nat)([p:nat](le (1) p)->nat n) .
Apply (well_founded_induction nat R R_wf).
Intro n.
Case n.
Intros.
Apply False_rec.
Inversion H0.
Intro n'.
Case n'.
Intros.
Exact (1).
Intro n''.
Case (even_odd_dec n'').
Intros.
Refine (S (H (div2 (S (S n''))) ? ?)).
Apply r2.
Assumption.
Auto with arith.
Generalize e H0.
Clear e H0.
Simpl.
Auto with arith.
Intros.
Refine (S (H (S (mult (3) (S (S n'')))) ? ?)).
Apply r1.
Assumption.
Auto with arith.
Auto with arith.
Defined.
Lemma le_1_3 : (le (1) (3)).
Proof.
Auto.
Defined.
The extracted function can be run in O'Caml:
let f x =
  let rec acc_rect x0 _ =
    match x0 with
      | O -> assert false (* absurd case *)
      | S n' ->
          (match n' with
             | O -> S O
             | S n'' ->
                 (match even_odd_dec n'' with
                    | Left -> S (acc_rect (div2 (S (S n''))) ())
                    | Right -> S
                        (acc_rect (S (mult (S (S (S O))) (S (S n''))))
Regards,
David.
David Nowak
LSV - CNRS UMR 8643 - ENS de Cachan
61, av. du Président Wilson, 94235 Cachan Cedex
tél: +33 1 47 40 55 69   fax: +33 1 47 40 24 64
http://www.lsv.ens-cachan.fr/~nowak/
