coq-club - Re: [Coq-Club] How widely applicable is Coq? (beginner)
chronological Thread
  • From: Christine Paulin <Christine.Paulin AT lri.fr>
  • To: Venanzio Capretta <Venanzio.Capretta AT sophia.inria.fr>
  • Cc: George Herson <gherson AT snet.net>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] How widely applicable is Coq? (beginner)
  • Date: Mon, 19 Aug 2002 14:10:47 +0200
Let me suggest an alternative solution which mixes Venanzio's solution
with an inductively defined domain predicate and David's solution with
well-founded recursion.
The idea is to define the domain predicate D but on the sort Prop such
that this predicate disappears from the extracted ML program.
Then the fixpoint is defined with a structural recursion on the domain
predicate D using the same trick as for well-founded recursion.
It works because the domain predicate can be "inverted" it means that
we can prove lemmas
 Lemma Deven_inv :
  (n:nat)(D n)->(lt (1) n)->(even n)->(D (div2 n)).
such that the proof (Deven_inv n p h1 h2) of (D (div2 n)) is
structurally smaller than the proof p of (D n)
The construction is done the following way
(* Domain definition *)
Inductive D : nat->Prop :=
   D1 : (D (1))
|  Dodd : (n:nat)(lt (1) n)->(odd n)->(D (S (mult (3) n)))->(D n)
|  Deven : (n:nat)(lt (1) n)->(even n)->(D (div2 n))->(D n).
(* Logical domain properties *)
Lemma not_D_O : (n:nat)(D n)->~O=n.
Lemma Deven_inv :
Lemma Dodd_inv :
  (n:nat)(D n)->(lt (1) n)->(odd n)->(D (S (mult (3) n))).
(* Some informative lemmas corresponding to the case analyses in the
program *)
Lemma odd_even_dec : (n:nat){odd n}+{even n}.
Lemma O_1_else : (n:nat){O=n}+{(1)=n}+{lt (1) n}.
Then the fixpoint can be defined the following way (the first argument
n of f is kept implicit) :
Fixpoint f [n:nat;p:(D n)] : nat :=
  if (O_1_else n) then
     [c01:{O=n}+{(1)=n}](if c01 then [c0:O=n]<nat>Cases (not_D_O p c0) of end
                         else [c1:(1)=n](1))
  else [clt1:(lt (1) n)]
       if (odd_even_dec n) then [codd:(odd n)](S (f (Dodd_inv p clt1 codd)))
       else [ceven:(even n)](S (f (Deven_inv p clt1 ceven))).
The extraction corresponds to the expected program :
Extraction Inline O_1_else.
Extraction f.
let rec f n = match n with
  | O -> assert false (* absurd case *)
  | S n0 ->
      (match n0 with
         | O -> S O
         | S n1 ->
             (match odd_even_dec n with
                | Left -> S (f (S (mult (S (S (S O))) n)))
                | Right -> S (f (div2 n))))
Proving the termination of this program corresponds to a logical proof
of (n:nat)(le (1) n)->(D n)
I attach the complete Coq script for this example.
Christine
Attachment: recursion.v
Description: Binary data
  Christine Paulin-Mohring             mailto :
  LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud,   91405 ORSAY Cedex
  LRI   tel : (+33) (0)1 69 15 66 35       fax : (+33) (0)1 69 15 65 86
  INRIA tel : (+33) (0)1 39 63 54 60       fax : (+33) (0)1 39 63 56 84
