- From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
- To: spitters AT cs.kun.nl (Bas Spitters)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] "For some" tactic
- Date: Thu, 8 Aug 2002 16:15:16 +0200 (MET DST)
Dear Bas Spitters,
> I want to define a "for some" tactic, which should do the following:
> For_Some t (P t)
> introduces a new variable t and adds (P t) as an hypothesis.
> When I do this naively:
> Assert ( EX t | (P t));Pick t. [Pick is a previously defined tactic].
> and I try For_Some t '(P t) coq complains that t was not defined.
Can you give more details on your implementation of Pick and
For_Some please? To my knowledge, defined tactic does not accept fresh
names as argument. Isn't "t" in "For_Some t '(P t)" a name (and not a term)?
> So, maybe, I should try doing something like For_Some [t](P t) and use
> pattern matching to get what I want, but apparently it is not allowed to
> pass a term to a user-defined tactic.
Yes, the following definition
Tactic Definition For_Some p :=
Match Context With
[ h : (ex ? p) |- ? ] -> Elim h; Do 2 Intro; Clear h.
works when called with "[t](P t)" as argument, but then you have no
control on the name of the witness (actually it will be a name based
on the radical "x" that is hard-wired in the definition of ex_ind).
Regards,
Hugo
- [Coq-Club] "For some" tactic, Bas Spitters
- Re: [Coq-Club] "For some" tactic, Hugo Herbelin
Bas Spitters
Bas Spitters
