coq-club - Re: [Coq-Club] "For some" tactic
chronological Thread
  • To: Hugo Herbelin <hugo.herbelin AT inria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] "For some" tactic
  • Date: Thu, 08 Aug 2002 16:47:51 +0200
Hugo Herbelin wrote:
 Dear Bas Spitters,
I want to define a "for some" tactic, which should do the following:
    For_Some t (P t)
introduces a new variable t and adds (P t) as an hypothesis.
When I do this naively:
 Assert ( EX t | (P t));Pick t.    [Pick is a previously defined tactic].
and I try For_Some t '(P t)  coq complains that t was not defined.
 Can you give more details on your implementation of Pick and
For_Some please? To my knowledge, defined tactic does not accept fresh
names as argument.
I defined:
Tactic Definition Pick x H := Case H;Intro x;Intro;Clear H.
Tactic Definition For_Some t H:= Assert for_some:(EX t |H); Auto; Pick t for_some.
Lemma test:(P:nat->Prop)(EX t | (P t))->(EX t | (P t)).
Intros.
(* Assert for_some:(EX t | (P t)).    <-  This works.
Auto.
Pick t for_some. *)
For_Some t '(P t).
But this gives:
Error: The reference t was not found in the current environment
Indeed, it seems that defined tactics do not accept fresh names.
Isn't "t" in "For_Some t '(P t)" a name (and not a term)?
t is indeed a name, below I was refering to the term [t](P t).
So, maybe, I should try doing something like For_Some [t](P t) and use
pattern matching to get what I want, but apparently it is not allowed to
pass a term to a user-defined tactic.
Yes, the following definition
 Tactic Definition For_Some p :=
   Match Context With
     [ h : (ex ? p) |- ? ] -> Elim h; Do 2 Intro; Clear h.
 works when called with "[t](P t)" as argument, but then you have no
control on the name of the witness (actually it will be a name based
on the radical "x" that is hard-wired in the definition of ex_ind).
Now I see that I can pass terms to defined tactics, but I can not use pattern matching on names.
Is there a good reason NOT to allow fresh names in defined tactics, or did it just turn out that way?
Thanks,
Bas
