coq-club - Re: [Coq-Club] double case analysis & recursion
chronological Thread
  • To: Dimitri Hendriks <Dimitri.Hendriks AT phil.uu.nl>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] double case analysis & recursion
  • Date: Thu, 12 Sep 2002 14:14:51 +0200
Dimitri Hendriks wrote:
The system complains that the following definition is not well-formed.
Fixpoint rm_last [A:Set;n:nat]  : (cp A n)->(cp A (pred' n)) :=
<[n:nat](cp A n)->(cp A (pred' n))>
Cases n of
| O    => [u:unit]u
|(S m) => <[m:nat](cp A (S m))->(cp A (pred' (S m)))>
 Cases m of
 | O => [t:A*unit] let (_,u)=t in u
 | k => [t:A*(cp A k)] let (a,t')=t in (a,(rm_last A k t'))
 end
end.
How to make it work?
Hi Dimitri,
I won't claim this is very elegant, but the following works:
Cases n of
| O    => [u:unit]u
|(S m) =>
 (<[m0:nat]m0=m->(cp A (S m0))->(cp A (pred' (S m0)))>
 Cases m of
 | O => [Heq:O=m][t:A*unit] let (_,u)=t in u
 | k => [Heq:k=m][t:A*(cp A k)] let (a,t')=t in
         (a,(eq_rec ?? [m](cp A (pred' m))
                (rm_last A m (eq_rec ?? [m](cp A m) t' ? Heq))
                ? (sym_equal ??? Heq)))
 end (refl_equal ? m))
end.
The problem comes from the fact that you are doing a dependent elimination and thus k must be an alias for (S n0), where n0 is the name of the predecessor of m (Coq substitutes pattern (S n0) for k). As a consequence, rm_last is applied to (S n0), which is rejected for the same as your alternative definition of pred' is rejected.
The funny(?) thing is that in the case of pred', since it is a non-dependent elimination, another choice is made for k: k is an alias for m.
The trick I propose is to abstract an equality property which allows to replace k (that is (S n0)) with m and vice versa. rm_last is applied to m (for the guard condition) and t' with its type changed, (cp A m) instead of (cp A k). After the recursive call, we must change the type the other way round.
I'd say this example raises an interesting question about typing Cases. It shows that we may want to have the choice between dependent and non-dependent elimination for each branch, and not only for a given Case expression...
Cheers,
Bruno Barras.
