- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Coq & Tla
- Date: Fri, 13 Sep 2002 04:14:14 +0000
Where can I learn about converting TLA+ syntax used
in 'Specifying Systems' by Leslie Lamport to Coq?
I assume it should be possible to do so. Is my
assumption correct?
Here is a simple example of TLA+ specification for an
asynchronous interface:
------------------ MODULE AsynchInterface --------------
EXTENDS Naturals
CONSTANT Data
VARIABLES val, rdy, ack
TypeInvariant == /\ val \in Data
/\ rdy \in {0, 1}
/\ ack \in {0, 1}
Init == /\ val \in Data
/\ rdy \in {0, 1}
/\ ack = rdy
Send == /\ rdy = ack
/\ val' \in Data
/\ rdy' = 1 - rdy
/\ UNCHANGED ack
Rcv == /\ rdy # ack
/\ ack' = 1 - ack
/\ UNCHANGED <<val, rdy>>
Next == Send \/ Rcv
Spec == Init /\ [][Next]_<<val, rdy, ack>>
THEOREM Spec => []TypeInvariant
- [Coq-Club] Coq & Tla, satrajit
