- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Can I add this axiom (without being inconsistent)?
- Date: Mon, 21 Oct 2002 11:32:01 +0200
Hello fellow Coq'ers,
Suppose we have a type T and an equivalence relation E on T, and two elements t1 and t2 of type T.
There exists the axiom "classic" (in classical_prop.v I think) with which I can state that (t1 E t2) \/ ~ (t1 E t2).
This expression though, has type Prop. Its Set counterpart would be {t1 E t2}+{~(t1 E t2)}. However it is known that adding the axiom (P:Prop){P}+{~P} make Coq inconsistent.
Now I was wondering if it is somehow possible to add an axiom to the Type level corresponding to the above excluded middle, that would allow me to decide whether t1 E t2 or not.
(I am trying to define the two vector vectorspace {v_1,v_2}, v_1 being the zero vector, so I need to define the action of some field on it. Now c.v_1 = v_1, but c.v_2 = v_2 only if c =/= zero. I need to provide an element v_i:(V::Type), so I'd need to eliminate the expression (t1 E t2) \/ ~ (t1 E t2) (::Prop) over V(::Type) which is not allowed. If I had (t1 E t2) \/ ~ (t1 E t2) :: Type, though, then I could.)
Jasper
+++ Out of Cheese error +++ MELON MELON MELON +++ Redo from Start +++
- [Coq-Club] Can I add this axiom (without being inconsistent)?, Jasper Stein
