coq-club - [Coq-Club] inductive and mutual inductive data types in Coq
chronological Thread
  • To: <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] inductive and mutual inductive data types in Coq
  • Date: Mon, 21 Oct 2002 11:52:33 -0400 (EDT)
The following example is given in the Coq manual for mutually inductive
types and it is followed by the comment below:
  Coq < Variables A,B:Set.
  Coq < Inductive tree : Set :=  node : A -> forest -> tree
  Coq < with forest : Set :=
  Coq <    | leaf : B -> forest
  Coq <    | cons : tree -> forest -> forest.
  This declaration generates automatically six induction
  principles. They are respectively called tree_rec, tree_ind,
  tree_rect, forest_rec, forest_ind, forest_rect. These ones are not
  the most general ones but are just the induction principles
  corresponding to each inductive part seen as a single inductive
  definition.
It is possible to get the more general induction principles?
The reason I ask is because I have the following definition of a tree
where the label at each node is a list of integers:
Inductive Tree : Set :=
  Node : (list nat) -> (list Tree) -> Tree.
It doesn't use mutual induction, but it also does not give me an
induction principle as general as I need.  I get a warning "Ignoring
recursive call", and the induction principle Tree_ind is:
Tree_ind
     : (P:(Tree->Prop))
        ((l:(list nat); l0:(list Tree))(P (Node l l0)))->(t:Tree)(P t)
I'd like the induction principle that assumes P for each tree in l0.
Thank you in advance for any information.
Amy Felty
