- To: Hugo Herbelin <hugo.herbelin AT inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Opaque in the library
- Date: Mon, 21 Oct 2002 19:00:08 +0100
Hi Hugo,
Hugo Herbelin writes:
> As far as le_lt_dec is concerned (and other lemmas from Peano_dec
> and Compare_dec), it is transparent in the current cvs version of Coq.
I'll be happy if new versions of Coq have these lemmas transparent for
computation, but in the version 7.3.1 library, that lemma is
permanently opaque.
BTW, the proofs in Peano_dec and Compare_dec use other lemmas. Are
all of those lemmas also transparent in the CVS version?
> As far as I know, the question whether a lemma is Opaque or not
> results of a compromise between the need for efficiency (transparency
> may induces very strong time penalty on type checking) and convenience
> for reduction.
Of course, but Coq implements a constructive type theory. Who ever
heard of a constructive type theory where you can't compute.
So we probably need more flexibility than Transparent/Opaque. Maybe
several levels of transparency, and tactics can specify which level
they will unfold. Maybe "Exact" and "Change" should see every lemma
as transparent. (If I say "Exact" and "Change" I mean it, why should
the tool not try to do what I say?). The Coq community may think
about other possible solutions.
> For which (other) theorems do you expect transparency?
What about course-of-values recursion over nat, induction_ltof1. This
is not usable for computation in 7.3.1. There are many other theorems
that probably should be transparent.
Best,
Randy
- [Coq-Club] Opaque in the library, Randy Pollack
- Re: [Coq-Club] Opaque in the library,
Hugo Herbelin
- Re: [Coq-Club] Opaque in the library, Freek Wiedijk
- Re: [Coq-Club] Opaque in the library, Randy Pollack
- <Possible follow-ups>
- Re: [Coq-Club] Opaque in the library, Cuihtlauac ALVARADO
Hugo Herbelin
