coq-club - Re: [Coq-Club] Opaque in the library
chronological Thread
  • From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
  • To: rap AT dcs.ed.ac.uk (Randy Pollack)
  • Cc: coq AT pauillac.inria.fr, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Opaque in the library
  • Date: Mon, 21 Oct 2002 19:17:02 +0200 (MET DST)
  Hi Randy,
> This function "shift" doesn't compute as I expected, because
> "le_lt_dec" is Opaque in the library.  Of course, this is just one
> lemma; I simply proved it again for myself, making it Transparent.
  As far as le_lt_dec is concerned (and other lemmas from Peano_dec
and Compare_dec), it is transparent in the current cvs version of Coq.
  As far as I know, the question whether a lemma is Opaque or not
results of a compromise between the need for efficiency (transparency
may induces very strong time penalty on type checking) and convenience
for reduction.
  For which (other) theorems do you expect transparency?
  Hugo
