coq-club - [Coq-Club] Inversion anomaly: Failure "try_find".
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Inversion anomaly: Failure "try_find".
  • Date: Thu, 31 Oct 2002 14:18:56 -0500
  • Organization: Yale University
Hi,
We met with a problem when encoding something using Coq 7.3. Here is a simplified version.
First, we define a "Type" T which depends on a "nat" n as follows:
Fixpoint T[n:nat] : Type :=
 Cases n of
 | O => (nat -> Prop)
 | (S n') => (T n')
 end.
Then, we define a relation R as follows:
Inductive R : (n:nat)(T n) -> nat -> Prop :=
  | RO : (Psi:(T O); l:nat)
          (Psi l) -> (R O Psi l)
  | RS : (n:nat; Psi:(T (S n)); l:nat)
          (R n Psi l) -> (R (S n) Psi l).
Next, we define two objects of type (T O).
Definition Psi00 : (nat -> Prop) := [n:nat] False.
Definition Psi0 : (T O) := Psi00.
So far everything is ok. Now we want to prove the following lemma:
Lemma Inversion_RO : (l:nat)(R O Psi0 l) -> (Psi00 l).
This lemma is true because the premise is false. It seems easily provable by doing inversion on (R O Psi0 l). However, when I did that , I got an error:
    Anomaly: Failure "try_find". Please report.
Is there a way that I can perform this inversion? I also tried Case, Elim, NewInduction , NewDestruct, etc. But after using either one of them, the Psi0 in the premise was changed to an arbitrary variable so I could not proceed.
Thanks for any help,
Dachuan
