- To: Pierre Courtieu <Pierre.Courtieu AT lri.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] "Opening" fixpoints
- Date: Thu, 31 Oct 2002 21:40:48 +0100
On Thu, Oct 31, 2002 at 06:45:35PM +0100, Pierre Courtieu wrote:
> In this case, you just need to reduce, for example with the Simpl
> tactic (see below).
> In the case where the decreasing argument does not start with a
> constructor (see how' below), then the only way I know is to proceed
> by case.
Thanks, indeed in my "real" lemma, I haven't a constructor
up-front. Case didn't do the job either, because of the specifics of
the actual "P" I had, itself a fixpoint. But generalising into a
theorem similar to the "How" of my message, proving it with the "Case"
and applying it where I had the problem worked great.
Lionel
pgpg6XseS9ejG.pgp
Description: PGP signature
- [Coq-Club] "Opening" fixpoints, Lionel Elie Mamane
- Re: [Coq-Club] "Opening" fixpoints,
Pierre Courtieu
- Re: [Coq-Club] "Opening" fixpoints, Lionel Elie Mamane
Pierre Courtieu
