- To: coq-club AT pauillac.inria.fr
- Cc: Hugo Herbelin <hugo.herbelin AT inria.fr>
- Subject: Re: [Coq-Club] Problemes with extendable grammars
- Date: Fri, 29 Nov 2002 13:13:41 +0100
Hugo Herbelin wrote:
I seize to opportunity to question the relevance of continuing
supporting Grammar (for constr) in the next versions of Coq knowing
that a new mechanism for symbolic notations has been developed. The
However it does not support recursive notations and hence does not
allow to write a list in a format like << a b c >> or {a;b;c;d}, etc.
I do hope that we can still use the Grammar subsystem for tactics though. (I mean "Grammar Tactic Simple_tactic := ..." etc., not just Tactic Definition.) Or alternatively that there is another means of defining this recursive-like kind of tactics. I mean, I very often use a self-defined tactic that takes a variable number of arguments; it acts exactly like Apply, which can have the form "Apply lemma" or "Apply otherLemma with arg1 arg2 ... argn", n depending on the lemma involved. Since I use it >1300 times, it +must+not+ go away!
Jasper
+++ Out of Cheese error +++ MELON MELON MELON +++ Redo from Start +++
- [Coq-Club] Problemes with extendable grammars, Pierre Casteran
- Re: [Coq-Club] Problemes with extendable grammars,
Hugo Herbelin
- Re: [Coq-Club] Problemes with extendable grammars, Jasper Stein
- Re: [Coq-Club] Problemes with extendable grammars, Pierre Casteran
Hugo Herbelin
