coq-club - Re: [Coq-Club] Problemes with extendable grammars
chronological Thread
  • To: Hugo Herbelin <hugo.herbelin AT inria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Problemes with extendable grammars
  • Date: Fri, 29 Nov 2002 13:22:16 +0100
  • Organization: LaBRI
Hi !
I plan to build a project in Computationnal linguistics on Coq.
It is important I can read/print sentences in another way than
binary cons-trees !
Pierre
  I seize to opportunity to question the relevance of continuing
supporting Grammar (for constr) in the next versions of Coq knowing
that a new mechanism for symbolic notations has been developed. The
new mechanism allows to define e.g. the concrete syntax for sig (both
parsing and printing) as simply as follows:
Notation "{ x : A | P }" := (sig A [x:A]P)   (at level 1).
  The new mechanism allows also to use the concrete syntax of operators
on Z or R (or even nat or positive) without quotes or double quotes
(one just says in advance what should be the default interpretation of
symbols in the current development).
  However it does not support recursive notations and hence does not
allow to write a list in a format like << a b c >> or {a;b;c;d}, etc.
  Hugo
Pierre Casteran,
LaBRI, Universite Bordeaux-I      |
351 Cours de la Liberation        |
F-33405 TALENCE Cedex             |
France                            |
tel : (+ 33) 5 56 84 69 31
fax : (+ 33) 5 56 84 66 69
email: Pierre . Casteran @ labri . u-bordeaux . fr (but whithout white space)
www: http://dept-info.labri.u-bordeaux.fr/~casteran
