- From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
- To: roconnor AT Math.Berkeley.EDU
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Reducing memory usage
- Date: Fri, 20 Dec 2002 13:54:21 +0100 (MET)
Hi Russell,
> Using my own Tacticals, I have create some proofs that have large proof
> objects. The .vo files are 10 to 20 megabytes.
> The problem is that when I import several these files (using Require) the
> memory consumption of the coqtop application gets enormous (300-400
> megs). Is anyway I can reduce the memory usage of the application. It
> seems unnecessary to load a gigantic opaque proof into memory.
Nothing is currently done not to load the opaque proofs into
memory. However a memory sharing strategy has been introduced in the
cvs version which provides gains of a magnitude of 3 in the average. I
integrated this memory sharing strategy to the bugs-fixes version of
V7.3.1 too. It will be available tomorrow on the anonymous cvs server
coqcvs.inria.fr (tag V7-3bugfix).
Hugo Herbelin
- Re: [Coq-Club] Reducing memory usage, Hugo Herbelin
- Re: [Coq-Club] Reducing memory usage, Russell O'Connor
