- To: Randy Pollack <rap AT inf.ed.ac.uk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Modules in V 7.4
- Date: Thu, 3 Jul 2003 14:36:41 +0200
Hello,
On Tue, Jul 01, 2003 at 03:13:45PM +0100, Randy Pollack wrote:
> Hello,
> I'm playing with modules for the first time. Here are some questions.
> Is it possible to have a hypothetical module?
The only way to do that is to construct a functor, with a parameter of type
Id.
Module F[Var:Id].
(* Here you can use Var *)
End F.
(* Here, you can't any more *)
> Since I don't see how to do that, I instantiated the signature with a
> ground module:
> However, I was surprised to see that I can also write
> Module Par: Id := Var
> and still have Var.X <> Par.X. Since modules have strengthening, this
> is against my intuition. What is the explanation?
It is exactly like in Caml...
If you write
Module Par: Id ....
than no matter how you implement your module (either directly or with :=Var),
you always get Par.X <> Var.X
However, if you write
Module Par := Var.
then (thanks to strengthenning) you get Par.X=Var.X.
If you want the signature Id to appear in your declaration, you can also
write
Module Par <: Id := Var.
This way you make sure that Par is of type Id and you do not put any
restrictions on the interface of Par.
I hope it answers your question.
Jacek
- [Coq-Club] Modules in V 7.4, Randy Pollack
- Re: [Coq-Club] Modules in V 7.4, Jacek Chrzaszcz
- Message not available
Randy Pollack
- Re: [Coq-Club] Modules in V 7.4, Pierre Courtieu
Randy Pollack
