- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Modules in V 7.4
- Date: Tue, 1 Jul 2003 15:13:45 +0100
Hello,
I'm playing with modules for the first time. Here are some questions.
Is it possible to have a hypothetical module? For example, consider a
signature of "identifiers"
Module Type Id.
Parameter X: Set.
Axiom Xdec: (x,y:X){x=y}+{~x=y}.
End Id.
It is obvious that this signature can be instantiated, e.g. by taking
X:=nat. But I only want an abstract module satisfying Id, so I'd like
to say (at the toplevel):
Declare Module Variables : Id.
Is there some way to do this?
Since I don't see how to do that, I instantiated the signature with a
ground module:
Module Var: Id.
Definition X := nat.
End Var.
Now I also want another module for parameters, Par:Id. I can write
Module Par: Id.
End Par.
and since Var and Par are abstract, Var.X <> Par.X, as desired.
However, I was surprised to see that I can also write
Module Par: Id := Var
and still have Var.X <> Par.X. Since modules have strengthening, this
is against my intuition. What is the explanation?
Best,
Randy
- [Coq-Club] Modules in V 7.4, Randy Pollack
- Re: [Coq-Club] Modules in V 7.4,
Jacek Chrzaszcz
- Message not available
Randy Pollack
- Re: [Coq-Club] Modules in V 7.4, Pierre Courtieu
Randy Pollack
Jacek Chrzaszcz
