coq-club - [Coq-Club] Mutual fixpoint definition problem
chronological Thread
  • To: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Mutual fixpoint definition problem
  • Date: Mon, 10 Nov 2003 14:35:38 -0500
  • Organization: Yale University
Hi all,
I have two inductive definitions which are very similar and want to convert a term of one to the other. But, the mutually recursive fixpoint doesn't work. I even tried unfolding the definition of "lift" below as mentioned in previous posts to the Coq list but it still doesn't seem to work?
Require PolyList.
Inductive def : Set
 := base : def
 |  lister : (list def) -> def.
Inductive deftwo : Set
 := basetwo : deftwo
 |  listertwo : (list deftwo) -> deftwo
 |  othertwo: deftwo.
Fixpoint lift [T:def] : deftwo
 := Cases T of
        base => basetwo
      | (lister L) => (listertwo (liftL L))
    end
with liftL [L:(list def)] : (list deftwo)
 := Cases L of
       nil => (nil ?)
     | (cons a L') => (cons (lift a) (liftL L'))
    end
This doesn't seem to work either:
Fixpoint liftL [L:(list def)] : (list deftwo)
 := Cases L of
       nil => (nil ?)
     | (cons a L') =>
         let lift = (Fix lift {lift [T:def] : (deftwo) :=
                    Cases T of
             base => basetwo
            | (lister L'') => (listertwo (liftL L''))
            end })
         in (cons (lift a) (liftL L'))
    end
Any suggestions? Thanks in advance,
--- nadeem
