coq-club - Re: [Coq-Club] Mutual fixpoint definition problem
chronological Thread
  • To: Nadeem Abdul Hamid <nadeem AT acm.org>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Mutual fixpoint definition problem
  • Date: Mon, 10 Nov 2003 20:57:20 +0100
Hi,
This works:
Fixpoint lift [T:def] : deftwo
  := Cases T of
         base => basetwo
       | (lister L) => (listertwo (map lift L))
     end.
Nadeem Abdul Hamid a ecrit :
 > Hi all,
 > I have two inductive definitions which are very similar and want to
 > convert a term of one to the other. But, the mutually recursive fixpoint
 > doesn't work. I even tried unfolding the definition of "lift" below as
 > mentioned in previous posts to the Coq list but it still doesn't seem to
 > work?
 > Require PolyList.
 > Inductive def : Set
 >   := base : def
 >   |  lister : (list def) -> def.
 > Inductive deftwo : Set
 >   := basetwo : deftwo
 >   |  listertwo : (list deftwo) -> deftwo
 >   |  othertwo: deftwo.
 > Fixpoint lift [T:def] : deftwo
 >   := Cases T of
 >          base => basetwo
 >        | (lister L) => (listertwo (liftL L))
 >      end
 > with liftL [L:(list def)] : (list deftwo)
 >   := Cases L of
 >         nil => (nil ?)
 >       | (cons a L') => (cons (lift a) (liftL L'))
 >      end
 > This doesn't seem to work either:
 > Fixpoint liftL [L:(list def)] : (list deftwo)
 >   := Cases L of
 >         nil => (nil ?)
 >       | (cons a L') =>
 >           let lift = (Fix lift {lift [T:def] : (deftwo) :=
 >                      Cases T of
 >               base => basetwo
 >              | (lister L'') => (listertwo (liftL L''))
 >              end })
 >           in (cons (lift a) (liftL L'))
 >      end
 > Any suggestions? Thanks in advance,
 > --- nadeem
 > Bug reports: http://coq.inria.fr/bin/coq-bugs
 > Archives: http://pauillac.inria.fr/pipermail/coq-club
 >           http://pauillac.inria.fr/bin/wilma/coq-club
 > Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Jean-François Monin           http://www-verimag.imag.fr/~monin/
VERIMAG - Centre Equation     tel (+33 | 0) 4 56 52 03 72
2, av. de Vignate             fax (+33 | 0) 4 56 52 03 44
F-38610 GIERES
