- From: Robert R Schneck-McConnell <schneck AT math.berkeley.edu>
- To: dehlinge AT dpt-info.u-strasbg.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] trying to use Init.Wf.Fix .
- Date: Wed, 5 May 2004 11:09:58 -0700
> I'm trying to translate the following function into Coq :
> f n = 0 if n=1
> f n = n+1 if n is even
> f n = n-3 if n is odd
No recursion means you don't need to use Fixpoint or Fix.
How about:
Require Export Even.
(* Must redefine this lemma with "Defined" instead of "Qed" *)
Lemma even_odd_dec : forall n, {even n} + {odd n}.
Proof.
induction n.
auto with arith.
elim IHn; auto with arith.
Defined.
Definition f (n:nat) : nat :=
match n with
| 1 => 0
| n =>
match even_odd_dec n with
| left _ => n + 1
| right _ => n - 3
end
end.
Eval compute in (f 5).
Robert
- [Coq-Club] trying to use Init.Wf.Fix ., dehlinge
- Re: [Coq-Club] trying to use Init.Wf.Fix ., Robert R Schneck-McConnell
