- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] trying to use Init.Wf.Fix .
- Date: Thu, 6 May 2004 11:41:42 +0200 (CEST)
- Importance: Normal
Oops ! Forgot the recursive calls...
The actual function I'm interested in is :
f n = 0 if n=1
f n = f (n+1) if n is even
f n = f (n-3) if n is odd
>> I'm trying to translate the following function into Coq :
>> f n = 0 if n=1
>> f n = n+1 if n is even
>> f n = n-3 if n is odd
> No recursion means you don't need to use Fixpoint or Fix.
> How about:
> Require Export Even.
> (* Must redefine this lemma with "Defined" instead of "Qed" *)
> Lemma even_odd_dec : forall n, {even n} + {odd n}.
> Proof.
> induction n.
> auto with arith.
> elim IHn; auto with arith.
> Defined.
> Definition f (n:nat) : nat :=
> match n with
> | 1 => 0
> | n =>
> match even_odd_dec n with
> | left _ => n + 1
> | right _ => n - 3
> end
> end.
> Eval compute in (f 5).
> Robert
- [Coq-Club] trying to use Init.Wf.Fix ., dehlinge
- Re: [Coq-Club] trying to use Init.Wf.Fix .,
Robert R Schneck-McConnell
- Re: [Coq-Club] trying to use Init.Wf.Fix ., dehlinge
