- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Re: trying to use Init.Wf.Fix .
- Date: Thu, 6 May 2004 15:48:20 +0200 (CEST)
- Importance: Normal
If you tried to run the proof script of the well-foundedness of l that I
provided, you didn't fail to notice there was a slight problem with it.
Here is the corrected version:
Lemma WFL :
well_founded l.
Proof.
intro n.
apply (lt_wf_ind n (Acc l)).
clear n.
intros n rec.
constructor.
intros y l1.
inversion l1.
generalize l1.
rewrite <- H0.
rewrite H1.
clear H1 H0 n0 l1 y.
intros.
constructor.
intros.
inversion H0.
elim (not_even_and_odd (S n)); auto with arith.
apply rec.
destruct n.
elim H1.
auto.
unfold lt in |- *.
rewrite minus_Sn_m.
simpl in |- *.
rewrite <- minus_n_O.
apply le_S.
apply le_n.
do 2 apply le_n_S.
destruct n.
inversion H.
inversion H6.
apply le_n_S.
apply le_O_n.
apply rec.
destruct n.
inversion H0.
unfold lt in |- *.
apply le_n_S.
simpl in |- *.
apply le_minus.
Defined.
- [Coq-Club] Re: trying to use Init.Wf.Fix ., dehlinge
- Re: [Coq-Club] Re: trying to use Init.Wf.Fix .,
Thery Laurent
- Re: [Coq-Club] Re: trying to use Init.Wf.Fix ., Jean-Christophe Filliatre
- Re: [Coq-Club] Re: trying to use Init.Wf.Fix ., Thery Laurent
Thery Laurent
